TR6 Clutch will not disengage
I had a similar problem I will bet it is still the throw-out bearing I went thru 3 new ones until it solved the issue I will not name the supplier. If that isn't the answer replace it with an automatic tranny
What was the issue with the TO bearing? You can send me a PM if you think it prudent.
I've the transmission bolted to the motor. I can turn the tail shaft with clutch pedal depressed but it is hard. I had to use a 12 inch bar to get it to turn but it does turn fairly easy with the bar.
What do you think about putting the rear wheels on the ground or locking the rear brakes and giving it a try?
I have been I contact with Moss tech. They are walking me through some specific checks to try to narrow down the problem. Progress is being made.
