TR6 CLUTCH ???????? TR6
saltshaker
Saturday while crusing I noticed shifting got harder and harder. It was almost like my clutch was out of adjustment. After limping home and checking, my hydraulic was low. What could have happened? There are no leaks showing. Is there some where to adjust the clutch or should I just make sure the fluid is checked regularly?
Novice in this area. Is it time to bleed the lines?
SUGGESTIONS???
Yep - first thing to do is a bleeding. Especially since you noticed the "hydraulic" was low. Report back.
Check to see if fluid is leaking into the footwell area. Clutch master cylinder may be leaking.
