MGB Clutch to floor 1978 MGB
Guywith2Mgs
have a 1978 MGB..was fine and then parked it in the garage for a few years. Went for the clutch and it is right to the floor. I'm a newbie to this but I thought there was a kit or something maybe from Moss Motors that let me replace the line and cylinder or something? Sorry...it's been a long time since I worked on the car and terms are slipping my mind with age...thanks for the help in advance!
You can replace it but, you probably don't need to.
1. It is not uncommon to have lost the fluid after a few years.
2. Your clutch is almost certainly stuck to the flywheel.
First of all bleed the clutch and get it hard.
Second look up videos on freeing a stuck clutch.
Don't immediately assume you need to replace anything.
