Woodie
Ok tonight I go back to my no clutch midget. I am going to rebleed the system using the bike tire setup. Now, when I lie under the car,andlook at the slave, whenthe clutch in not depressed, how far is the rod extended from slave, or is it fully pulled back into the slave.
Second question, when the clutch is depressed, how far out of the slave is the rod extended? or maybe the better question is how far should the clutch lever pivot from its resting point (no pedal applied)??
I want to make sure the travel is right, before I do anything harsh, if the rebleed does not fix the problem.
Thanks guys
Thanks guys
