As mentioned in a previous thread I'm thinking of replacing my clutch. I have done some research on the web, and read the stuff at Buckeye Triumph.
The current clutch in my car is the Laycock unit with the RHP bearing.
It looks like there is considerable wear on the fingers:
Does this wear indicate that the RHP bearing is due for replacement?
The fork looks almost new, and has a pin in it, so I'm not going to replace it:
I have owned the car for 22 years and during that time I've not done any work to the clutch, but from the above it looks like the fork was replaced somewhere along the line and maybe the release bearing as well. This would have been done prior to 95, as that's when I purchased the car.
Does the ware on the fingers indicate that the release bearing needs to be replaced, or is it just typical wear for a clutch with 80K miles on it? How can I tell if the release bearing needs to be replaced?
I am looking for a light clutch pedal (due to lots of stop and go traffic and arthritis) and so I'm thinking of getting the Sach clutch possibly with the Toyo release bearing. I'd like to hear opinions on this combination.
Thanks
Todd
Thanks
Todd
				 Hi Guest!
Hi Guest!
 but were afraid to ask:
but were afraid to ask:  STOP!! Never post your email address in open forums. Bots can "harvest" your email! If you must share your email use a Private Message or use the
STOP!! Never post your email address in open forums. Bots can "harvest" your email! If you must share your email use a Private Message or use the  smilie in place of the real @
