I have a 76TR6 with 65000 miles on it. Lately I have noticed an intermittent clack coming from under the car while cruising down the road. If I gently place my foot on the clutch pedal the clack goes away.
After investigating further with the car on the hoist I found that there is play in the throw out bearing lever. There is play in the slave cylinder pushrod allows the lever to float very slightly. With the engine running the lever traveling slightly forward causes this loud metallic clack inside the bell housing.
This cannot be a good thing. What could be happening here? Would it be an idea to insert washers between the slave cylinder and its mount to eliminate the slack and resulting freeplay? I have as well considered attaching a spring to the lever to keep it from floating? Has anybody experience of this type and have any suggestions?
I should add that I have noticed that I can hear the throw out bearing while seated in the car, alongside a building or in the garage etc.
I have replaced and/or rebuilt just about everything on the car except the clutch. Am I faced with the inevitable clutch replacement as a winter project or can I cheat a bit with some adjustments.
