Dr_EluSivE
Its seems as though i have trashed my clutch somehow, It works for a mile or so and then Will not Disengage. When you push in the Pedal it feels Like there is clutch, But i get a grinding sound as well and the car will not go into gear when running. So i plan in the spring to pull the tranny out and replace the clutch and Release bearing. I have a feeling that my carbon pad on the bearing crumbled and now i have no clutch. Has anyone ever used one of the Roller bearing replacement release bearings that minimania Sells for the spridgets? Seems like it would be a worthwhile upgrade, but i only want to do it once, so i am looking for advice. Clutch has not been touched for about 12 years. Also, are Mini Slave cylinders and Midget slave cylinders the same? Thanks for the help
Dr.
Dr.
