Clutch Problem - Seeking Input
JBlubaugh
Hi all -
Looking for some input / guidance before I pull the transmission out of the car.
Car : 1960 BT7
Problem: Grinding noise when clutch pedal is pushed in
Last week while driving the car I noticed I had a slight grinding sound coming out of the clutch area with a slight smell of something burning. I put it up on the jack stands and took a look underneath. I noticed the slave cylinder was leaking some fluid so I thought that might be the issue, not disengaging the clutch when depressed. I changed out the slave cylinder and started it up.
The noise continued and when I depressed the clutch pedal in, the noise grew in both sound and intensity to the point where the engine stalled out. I'm pretty much resigned to the fact I will have to pull the tranny, just curious as to what everyone thinks could be the problem.
One interesting thing....When I mated the transmission back on after an engine / transmission rebuild about 4 years ago, I could never get the clutch to disengage, it would always drag. I modified a pin to be 1/3 inch longer than normal and used that in the slave cylinder with no problems. I could never understand why the original pin didn't work if the slave mount points where on the block/bell cover. Is it possible something was not aligned correctly during the rebuild?
Thanks for reading and for you input.
Jim
CanberraBJ8
Is that the thrust bearing complaining? Or maybe there is some broken clutch fingers?
5
57_BN4
Sounds like the carbon release 'bearing' is worn down. Beware of reproduction ones, they may only last a short time but you can find original AP ones on Ebay. Before you put it back together you need to be sure the little plate the release block presses on is A flat, B shiny and C even or it will fail quickly again.
I had mine surface ground on a flywheel refacer then spent an evening on the lapping block with gradually finer grit until P1500, then I put a dial gauge on it while fitted to the installed clutch and adjusted the lever fulcrum points until there was no runout on the plate face. After fitting the gearbox and operating the clutch a few times to centralise everything and making a few more adjustments I then tig welded the locknuts that hold the fulcrum adjustments since they are only lightly staked with a screwdriver.
Andy.
Keith_M
This sounds like the throw-out (release) bearing....
Keith
Johnny
Good advice. I always have the flywheel re-surfaced, it does make a difference. When putting the flywheel back on follow the instructions in the manual or you'll be doing it all over again. It helps to have the engine at TDC on #1 piston.
Govtslug TR6 Clutch Problem Triumph 21
T TR2/3/3A TR3A clutch problem Triumph 15
E TR2/3/3A Tr3 a clutch hydraulics problem, again. Triumph 16
Healey Nut Clutch problem Austin Healey 5
R TR2/3/3A Tr-2 Clutch Problem Triumph 46
P TR6 Clutch problem not solved Triumph 6
MKIII_Joey Clutch Problem Austin Healey 5
M BJ8 Clutch Problem Austin Healey 4
T TR4/4A clutch problem on brand new TR4a Triumph 6
T TR6 Problem with Clutch on 1976 TR6 Triumph 12
G MGB Clutch problem MG 7
F BT7 3000 - Push rod problem on clutch slave cylinder Austin Healey 7
I TR2/3/3A Clutch and brake pedal assembly problem Triumph 4
aeronca65t Clutch pedal problem- 1275 race car Spridgets 12
M Clutch problem, a little different than usual Spridgets 8
U Spitfire Help - Clutch Problem on the Road! Triumph 11
M TR2/3/3A TR3A clutch hydraulic problem Triumph 9
K TR2/3/3A Complicted Clutch Slave Problem TR3A Triumph 12
G TR6 TR6 Clutch Problem Triumph 22
aeronca65t Common problem-clutch pedal Spridgets 2
smaceng Clutch Problem Jaguar 3
D TR6 New poster, TR6 clutch problem Triumph 10
Jims71TR Clutch Problem need Help Triumph 14
tahoe healey clutch problem Austin Healey 14
F TR6 triumph tr6 clutch problem Triumph 14
T Sqeeling Clutch Problem..SOLVED Triumph 2
S TR2/3/3A TR3 clutch pressure problem - not a broken spring! Triumph 3
AngliaGT Clutch Problem Other Cars 9
TR_JOE250 Spitfire Spitfire clutch problem Triumph 22
F 67 austin healey 3000 clutch problem FORUM Navigation Questions 0
F 67 austin healey 3000 clutch problem Austin Healey 20
RickB Clutch problem this morning MK2 Sprite Spridgets 4
M A possible problem with the clutch Spridgets 8
bluemiata90 TR6 TR6 clutch issue, Possible bleeding problem ????? Triumph 4
A TR6 TR6 Clutch Problem Triumph 11
J T-Series clutch problem MG 13
F Frogeye clutch problem Spridgets 10
R Clutch Sticking Problem Austin Healey 4
Brosky Typical, but lucky, nice day problem [Clutch] Triumph 13
Sarastro Yet another odd clutch problem. Spridgets 5
Brosky TR6 TR6 Clutch knocking noise problem [not mine] *DELETED* Triumph 2
simpzimmer Found the Clutch Problem Triumph 1
simpzimmer Clutch Problem Triumph 1
DerekJ Clutch problem - I think! Austin Healey 14
B Do I have a problem with My New Clutch ???? Austin Healey 3
M TR6 76 TR6 clutch problem Triumph 3
G TR6 TR6 Clutch Problem Triumph 5
MattP T-Series Clutch Problem? MG 3
EMGEBE T-Series Is this a clutch problem? MG 2
