Clutch Pilot Bearing
sail
664A Can I take the old pilot bearing out and replace w/removing the flywheel?
I don't believe so. The hole in the stock flywheel is smaller than the bearing od.
But fortunately it's not that hard to R&R the flywheel, once the gearbox is out of the way. I used a big screwdriver & a bolt to jam the flywheel teeth, but a purpose-made tool would probably work better.
