Clutch MC Rebuild Question
Bruce_B
I'm changing my 59 bugeye to a dual brake MC and a clutch MC. I'll be buying a new dual brake MC and I have a clutch MC that I removed about 2 years from a 74' Midget - working at the time.
Two Questions:
(1) Should I rebuild the clutch MC as long as it's out of the car?
(2) how much work is it? doesn't seem that bad from what I've read in the archives.
Any tricks or Tips? Any recommendations for vendors for the kit? do any vendors rebuild these?
thanks.........
Easy. Just be sure to lightly hone the cylinder. Also, be sure the hole in the clutch pedal isn't elongated.
You'll need to dismantle the cylinder first to determine which of the 2 kits you need. Either 1 cup + 1 seal or 2 seals. Check the usual suspects' online catalogues.
Peter C
