I have a 5/8" Nissan hydraulic clutch master cylinder (Smitty's conversion) on my car. I noticed a leak at the cylinder over the weekend and while I was tightening the flare nut on the line to the slave cylinder I saw
something that has me confused:
There are two ports (tapped holes) on the cylinder body with a hydraulic hose to each, one in the middle of the body and one toward the closed front end of the cylinder. I would expect that the supply line from the hydraulic reservoir would be connected to the port in the middle of the cylinder and that the line to the slave cylinder would be connected to the port on the closed front end of the cylinder. Mine is hooked up just the opposite and the line going to the slave connects to the port in the middle.
Is this setup correct?
BTW the clutch works just fine.
