Got_All_4
Started noticing last week after 400 miles and after rebuild that the clutch was getting a mushy feel. (rebuild means the car, including clutch plate replaced, through out bearing and a thorough bleeding of hydraulics). Turns out there is now a 1/2 inch of play in the master cylinder push rod. Last week it might have been 3/8" so it could be getting worse. Fluid level is at the top. I can push the rod forward a 1/2" before it hits the piston. What could be going on?
Another problem has arrived with the water pump after a 50 mile ride tonight. I'll post a separate message.
