racingenglishcars
Just my humble opinion.
That's a Datsun engine, trans and slave cylinder. It was working and suddenly it's not. To me it sounds like the pressure plate (diaphram type) has broken and forced the T/O bearing back. This would give a soft clutch and appear as though there is air in the system. All the bleeding in the world won't help that. It most probably needs a new clutch pressure plate.
To check it, I think you can use an inspection light and look through the clutch fork access hole. But don't expect to see much. One of the clutch fingers would be a little depressed from the others. Or yank the engine out. It really doesn't take that long. And the Datsun engine is really quite easy. (in a Datsun)
Hi Guest!
