mrsprite
This is sort of long.....I apologize.
I have been having all sorts of issues with my clutch lately. It started with a bad master cylinder. It is a stock 7/8" unit, which may be part of the problem since I am using disc brakes up front. It was rebuilt and all was well for awhile.
Then I had issues with the slave cylinder, which is the stock Datsun piece (I have a Datsun A15 engine & 5-sp.). I bought a new one, but the previous owner modified it to fit within the Bugeye's frame rail, so unless I drilled and tapped a new hole for the hydraulic line it wasn't going to work. So I just rebuilt the old slave with the guts from the new one and it worked well for awhile, but the pedal would go soft after driving/using the clutch. It seems the hydraulic line to the slave was dripping.....it is a later flexible hose from a 1275. I tightened it up the best I could and it still didn't seem right. Now it appears the line is leaking around where the end is crimped to the hose. I ordered a new hose from Moss, but it hasn't arrived yet. My question (after that way too long of a set-up) is this.....is there anything I can do to temporarily "fix" the hydraulic line so I can at least drive it?
Right now I am getting very little to no clutch action and it is impossible to shift. I have been matching revs the best I can, but I still grind gears. There is a neat cruise this Saturday put on by the local British car club (lots of twisty mountain roads) and I want to participate, but unless the hose gets here tomorrow or I find a way to bandage it up it looks like that's going to be a no-go.
Any suggestions?? Or am I screwed?
Thanks.
Thanks.
