I have just finished a total restoration of a 1954 TR-2 Long Door. It has a new clutch, slave cylinder and master cylinder. I have everything together and adjusted according to the specs. I have adjusted the slave cylinder rod according to the spec's and the transmission will go into all gears without grinding.
My problem is the clutch will not engage until the pedal is all the way to the top. I can shift to the gears but no engagement until the pedal is at the top? This creates a dangerous situation when you need to hit the brake in a hurry.
Any ideas on how make a adjustment to lower the engagement closer to the floor?
Dick
Dick
Hi Guest!
