Clutch Adjustment
65_BRG_Sprite
Car was a complete tear down and rebuild. I tried to put the clutch pedal assembly back to original adjustments but probably am off. Clutch is bled; now how do I go about adusting from the beginning to end?
Set your stop's so that there is just a tad bit of play between the end of the master push rod and the piston in the master when in the released position. That is all that is critical. Clevis adjustment and stops can be made to suit where you want your pedal to be as long as you remember the push rod clearance bit.
Kurt.
