brucebotti
I'm working on a friends 1974 TVR with a TR6 drivetrain. We just had the trans rebuilt by Quantum Mechanics (John is a great guy!). We also installed the TRF magic clutch with the Gunst bearing and all new hardware, new slave, rebuilt MC, etc. When its cold, the trans grinds a little on a normal upshift. Even when warm, you have to make sure the clutch is fully depressed and that you shift precisely otherwise you get a slight "hangup" (less than a grind). It may be because everything is new and needs to break in. Its probably the same on my TVR but I just never noticed it. Finally my question...I have the clutch slave push rod in the center hole on the cross-shaft. In your experience, if I move it to the upper or lower hole, will this increase the throw at all?
Thanks in advance!
Bruce
Thanks in advance!
Bruce
