RickPA
67 BJ8 - Chased down a knock in the front suspension to slight vertical motion in the steering idler. I've never had this guy apart (until now). The lever arm was pressed on the splines of the shaft very tightly but not snug up against the bottom of the idler body. This allowed about 1/16 to 1/8" up/down play of the shaft before the top of the shaft contacted the cover of the idler causing a clunk. Should I press the lever arm onto the splines of shaft until it is snug against the oil ring at the bottom of the body or is there​ supposed to be a certain amount of play so it doesn't bind?
