TR2/3/3A clanking sound at idle on TR3
Kleykamp
Car idles around 700 rpm's. Slightly rough idle but acceptable. I get a clanking rattle with no particular rhythm at idle. ( take two box wrenches and hit them together ) metal to metal clank. If I increase the idle speed it goes away. I have driven the car now, several times and it runs very well on the road and has actually been "pushed" spiritedly a few times. No strange noises under driving conditions. The sound seems to come from under the engine. Should I suspect anything in the crank,pistons,rod bearing area, or just keep looking for something loose? Sound does not change when clutch depressed. Had transmission out and replaced clutch. T/O bearing was OK. I have reached around under and around the engine trying to find something loose but nothing found. Any suggestions for diagnosis?
Kleykamp
Kleykamp
Quick addition: I have placed long screw driver on head, block,water pump,timing chain cover, generator and listened through that. No strange noise other than the sewing machine sound.
MDCanaday
If the spring steel timing chain tensioner fails, it often makes a noise like this.the outer shell fractures off and is just banging about inside the cover making an irregular tinking sound. This is a precursor to a total failure as the chain will soon jump time,and the bits of steel in the oil domajor damage to the front main bearing.....
MD(mad dog)
TR3driver
Great Pumpkin - R.I.P
Sounds somewhat similar to what I had when the front hub was coming loose on the crankshaft.
I had removed the fan and extension (to make room for an electric puller) and installed a shorter bolt & big flat washer to clamp the hub in place. But the washer pulled up against the end of the crankshaft with the hub only partially clamped, so the hub eventually started to work back and forth. Timing chain tensioner was broken too but I think the hub was making the noise.
Anyway, just a thought for something to look at.
PeterK
My front bumper brackets (the roundchrome tubes) used to rub against the holes in the grille and make a squeek only at idle that I was sure was the water pump pulley rubbing.
So look around outside of the immediate engine as well.
TuffTR250
If you still have the old metal fan, check that the rubber mounts are still good. If they are deteriorated it could let the fan move and you may get a clanking sound.
Regards,
Darrell_Walker
Does the rough running also cause the engine to bounce around? If so, I'd also check out the exhaust system.
TimK1955tr2
I had the woodruff key on the water pump pulley wear, allowing the pulley to hit the WP mounting nuts causing a similar sound. with engine not running, see the the pulley rocks on the shaft. also, maybe check the generator attachment bolts and mounts.
Kleykamp
Kleykamp
Some great ideas so far, especially since no one has indicated they thought the main, or rod bearings were suspects. I initially thought of the timing chain, but wouldn't my "crude" mechanics stethoscope have picked up that additional noise when held on the timing cover? Could be wishful thinking on my part, due to not wanting to remove my freshly painted front nose from my freshly painted fenders. I'll check the fan and pulley. I recently replaced the generator mounts and had the front plate of the generator welded up for the bolt hole being worn through.. I thought that was the problem, but the repair didn't stop the noise. Thanks for all the input,it helps me keep eleminating things as I run out of ideas.
mallard
This is a wild idea but I've heard the pistons in the Strongberg carbs smack up and down if they were dry inside (no oil). I don't know if the SUs could do the same thing.
vivdownunder
Being down low, it could be a crankshaft thrust washer failed.
Or perhaps too much camshaft end float allowing back and forth movement. (tolerance 0.003" to 0.0075") Don't worry too much if it's the cam as they can clunk away for years without trouble.
Viv.
Addition - strangely a wide fanbelt cracked on the narrow side can make a terrible mechanical noise at idle. First time I heard it I thought I had a broken chain tensioner.
Kleykamp
Kleykamp
Appears the fan is the culprit. I can rock the fan on the hub and produce a noise. Good new/bad news in that I still have to disassemble my freshly painted body panel. It seems I need the rubber bushings and sleeves in the fan blade assy. I still like that much better than timing chains and bearings, just have to inlist some assistance in removing the front panel to avoid catastrophe to new paint. Falls under the catagory of, I should have done that while I was in there. Thanks again for the input. I'll start on that project on another day,just enjoying looking at the car right now.
mrv8q
Kleykamp said:
Appears the fan is the culprit. I can rock the fan on the hub and produce a noise..
Original fan, or the TR6 fan?
TR4nut
Not sure how much clearance you have between radiator and the lower front apron - but I'd check if I were you to see if you can avoid pulling the apron. Removing the radiator guard and the lower radiator mounting bolts may give you just enough room to pull the old fan.
Kleykamp
Kleykamp
Have the original fan. Appears the rubber bushings have dry rotted and allows the fan to rock back and forth on the bolts. Thinking of looking into the plastic fan though.
Randy, I thought about checking from under the car to see if maybe it could be done from there,but probably still would have no knuckles left,after working that close to radiator.. I think the crank bolt has to come out and it is pretty long. Haynes manual has to remove apron. I'm thinking about waiting and getting a new radiator at the same time and do it all at once.
TR3driver
Normal assembly order is to install the long crank bolt first. The fan assembly actually includes a lock plate to hold the long bolt from turning. So you don't need to remove that bolt to replace the fan bushings.
However, I agree, pull the apron. Even if you take the radiator loose on its mounts and move it as far forward as possible, there still isn't really enough to put things back together properly.
The good news is that, if the bolts aren't rusty, it only takes an hour or so of steady work to remove the apron. You should be able to complete the entire project in an afternoon.
The hardest part is what to do with the apron once it is off. When I did this a few years ago (before converting to an electric fan), I foolishly left it balanced on one side. A gust of wind blew it over and banged up the paint around the grille.
Don Elliott
I had a rattling sound in my 1958 TR3A in 2003. It sounded like about 10 tea spoons in a tin cup being shaken.
It was intermittent and only ever happened at idle. It was the starter where the small drive pinion gear was not completely retracting from the teeth around the flywheeel. I pulled out carb #2, then the starter and re-built the starter. After that - no more rattling.
Kleykamp
Kleykamp
Don,
Funny...or not so much...you should mention that. See my latest post regarding starter issue. I'm sure I have a rattling fan, but my have been some in the starter too.
G Clanking noise is getting worse on startup..... Triumph 25
S Clanking noise MG 16
Patrick67BJ8 Insulation and Sound Deadening Austin Healey 0
M TR6 Clicking sound when accelerating Triumph 11
tr6nitjulius General TR Sound of TR6 Side by Side singing 2gether Triumph 0
tr6nitjulius General TR Sound of 1972 TR6 engine! Triumph 3
nichola TR6 Stock exhaust sound... short video Triumph 4
EWD TR6 Sound/Heat Mat installation - 74 TR6 Triumph 14
J TR6 Does this sound ok to you? Triumph 5
EWD TR6 ‘74 TR6 Interior - Padded dash and heat/sound material Triumph 4
RAC68 Loose Metal Knocking/Banging Sound during Rough Idle Austin Healey 32
DerekJ Sound proofing recommendations Austin Healey 8
T TR2/3/3A Does this sound like fuel pump problem? Triumph 15
maxwedge5281 no sound when breaking the christmas bulbs??? Austin Healey 16
M TR2/3/3A Electric Fuel Pump Sound Triumph 7
HighAltitudeTR3 TR2/3/3A How does this sound?! [Video] Triumph 8
HighAltitudeTR3 TR2/3/3A How does this sound?? Triumph 6
C A better sound for a Miata? Other Cars 0
GTP1960 TR2/3/3A Loud scraping sound in clutch area Triumph 12
T sound for a bug-eye??? Spridgets 2
N MGB-GT Carpet, sound proofing, and painted bumpers, Oh My! MG 15
W Sound 1966 Sprite rolling chassis Spridgets 0
HealeyRick Alternative Sound Systems Restoration & Tools 2
AN5Sprite F1 Sound Comparison 2013 vs 2014 Racing 2
Boggsy64 MGB Sound deadener MG 4
drambuie No sound affects when breaking those little Christmas lights! Austin Healey 16
M Replacement Sub-Woofer for X308 99 XJ8 with Premium Sound System Jaguar 1
drambuie Getting a better deep throaty sound from my Stainless exhaust Austin Healey 5
JPSmit What is that strange grinding sound in the distance? Spridgets 3
C BJ8 Stainless Steel Exhaust - throaty sound ? Austin Healey 4
KVH Strange Sound Like Compressed Air Escaping Triumph 14
T TR2/3/3A Has anyone put sound deadening in a TR3. Were the results worth it? Triumph 21
P Engine noise ~ Garbage disposer sound Triumph 9
7 squealing [Humming] sound rear DRUM brakes Other Cars 3
G Undercoating/sound deadening removal Spridgets 5
M Sub-woofer Speaker for 99 XJ8 with Premium Sound Jaguar 1
regularman heard a clicking sound and found the cause Spridgets 6
bugedd The sound of silence Spridgets 9
M exhaust sound different. brith/jap Spridgets 14
T Scraping sound and puddle Triumph 2
T What do these symptoms sound like to you? Triumph 22
DNK Por 15 & Sound Proofing Triumph 9
Musicman Strange Clicky/Tappy Sound Triumph 6
DNK Out in the Sound... Spotted 3
tr5er sound problems Triumph 13
G Healey Sound Austin Healey 15
RichBall Oh, That Sound Spridgets 19
DNK 'Nother Dreaded Sound Deadening Question Triumph 19
Gundy New video w/ sound Spridgets 22
Superwrench sound deadening Austin Healey 2
