Chrome alternative
rkep01
Just discovered this website today - https://coatofchrome.com/home.php. Looks intriguing. You have to send him a part for him to quote the job. The good part of this process is that it can be done on any material, which means that he can fill pits with plastic filler and sand smooth, then coat it. I'm going to send him a small part to see how it works out. I'll report back in a few weeks when I get the part back. Check out some of his stuff.
He must be pretty good if they're letting him plate the Ark. :laugh:
How do auto manufacturers chrome plate plastic? There seems to be plenty of modern chrome plastic on cars that is pretty durable.
It's done by a process known as vacuum metalizing. Vacuum metallizing is a process where a metallic coating material is placed in a vacuum chamber with the workpiece to be coated. The material that is being applied is then heated until it starts to evaporate; this vaporized metal condenses on the product or workpiece as a thin metallic film. As this is happening, the part is being rotated for uniformity of the coat. Thin layers of paint can then be applied to produce other colors. Once complete, a clear sealer is usually added to prevent flaking.(a/p Wikipedia) This process, according to the website, is more like the silvering of a mirror and is done by spraying the metal onto the object. The photos look very impressive.
Gosh, Mike - did you send them your whole car?
Doug
I have something similar called mirra chrome from Alsa paints. Theirs supposedly has the most reflectivity. I bought some but have not used it yet. $80 for 4 ounces and that is already thinned. I have a set of wire wheels and was thinking about doing those.
I'm going to send him the parking brake handle. That should be a good test.
Caswell plating has a paint w/ silver in it used to plate plastic. Spray w/ the paint then plate.
Remember, that paint is not going to stand up like real chrome as far as something like that handle where it can get scratched. That is some serious corrosion. There have got to be people on this board that have extras to send you one of those. They are not bad to break down and get like that. I might have already thrown one out.
You must not have seen the first Indiana Jones movie. That thing is off the hook! :jester:
Rep, that is a lot to smooth and fill. I can see it for a test for more expensive stuff. That brake handle will probably cost two or three times what it's worth when done.
IIRC, there's a German company called Chrome Solutions that deals in this stuff. Jay Leno's Garage did a video on the process. (here's the link.) Looks pretty easy to do at home. Don't know how expensive the chemicals are, but it'd be neat to be able to chrome anything at whim.
As I said in the original post, this is an experiment to see how good this process is and what the price is compared to re-chroming. What better part to send than one like this that has many faults and will be subject to some wear and tear? I know I can get another one, but that isn't the point. The corrosion is just from where the original plating has worn off. I have already cleaned that up. The pitting that has been left, will be filled with ordinary body filler and sanded by the person doing the process as opposed to cleaning, braze filling and grinding smooth each pit by the chrome plater. That's where the real cost in plating comes about. That and the cost of having to legally dispose of the chemicals. Granted that it may not be suitable for all applications, but if we can find an alternative to chrome plating that will hold up decently and be less expensive, it will be a good thing.
I'd be really interested in getting some more info on this process...if it really is that 'simple' I would at least give it a shot in my garage...
kellysguy said:
An easier RB to CB conversion! :laugh: :pukeface:
Wha? :confuse:
Rubber bumper to chrome bumper. Could you imagine what Midget rubber bumpers would look like with that stuff sprayed on them?
