The sad remnant of my brain is losing patience with the tree lights. All five strings worked fine last year - of course this year, four of five strings are dead in the water.
LED bulbs, 125v AC, fuses and fuse holders test fine. End of the string has 125v, so current is making it through the system. But not one bulb is lit.
It's a "three wire" system, which should allow working bulbs to light, even if a few are dead. Each string plugged into power outlet alone is dead too.
Seems weird that one string works fine, but the other four strings all have the same dead bulb situation!
Tom M.
Tom M.
Hi Guest!
