Choke sticking
Michael Oritt
Detaching the cable from the choke arms will enable you to determine if the "stiffness/stickiness" is in one or both of the carburettors or the choke cable--or both. I have never had to lubricate a cable but should that be the cause it is not too difficult to work a lube into the cable jacket--perhaps dry graphite powder would work.
Common problem with BJ8s. The choke return springs on the carbs are too weak (I guess too strong and you'd have to be The Rock to pull the choke knob). I've tried everything: cleaning and lubing all shafts in the carbs, lubing the cables, etc. The only thing that really works is to rig some extra return springs attached to the enrichment arms on the carbs. I finally gave up; since you usually only need enrichment--SUs don't have 'chokes'--on the first/cold start after I check the oil I leave the bonnet open and start the car, when it's warm enough to run I push the arms down manually.
wangdango
I have not tried it yet, but Norman Nock has some springs which are added between the cable and the lever arms, (I am just going to use a hardware spring of appropriate size). Check out their website for parts and you will see how it works.
steveg
This originally called for "ballpoint pen" springs.
Patrick67BJ8
I had added extra springs connecting the choke enrichment levers from the carbs to the wheel well. It eventually wore out the bushings on the carbs plus it was harder to pull out the choke. This was after I removed the choke enrichment levers from the carbs and cleaned and lubricated it. The original springs work great as long as you keep everything clean and lubricated. Another issue was the choke cables being worn out. I cleaned and lubricated them with graphite and they worked so so. I replaced the choke cables with bike cables and my carb choke works great! Best thing I’ve done for my BJ8 chokes since buying my Healey since 1972. I also purchased springs from BCS to assist in the chokes going full off when choke is released. Several years ago many of us used a couple of ball point pen springs to do the same thing.
Healey Nut
Glad to hear Im not the only one who does this .
Lin
Bob, I am sure this comment will start another discussion about how to properly warm up the engine, but the problem with your approach to pushing the arms down manually is that I assume (always dangerous) that you are pulling the “choke” on, starting the engine, and then letting it sit to warm up. I have been told by a number of people - the latest being Jeremy Welch, of Dennis Welch Performance - that one should “choke” the engine and then drive it immediately to warm it up rather than letting it sit and idle to warm up. Without a return spring on the choke arms you would have to drive the car, get out and open the bonnet and push the arms down.
I have made a modification to the choke bracket similar to what Steve Gerow did and I use the two ball point springs that has been mentioned. This works just fine resulting in proper on/off of the “choking” mechanism. Though I have a BT7 I run HD8 2” SUs with a BJ8-type firewall choke bracket. I love being in the Healey once I am there, but I try to minimize the number of times I have to get in and out of it!
All the best,
Lin
Michael Oritt
Lin/All--
I can't imagine why Welch would suggest driving off immediately since the most important reason to "warm up" an engine--especially a race engine--is to get the oil temperature up a bit so that it offers proper lubricity to critical parts such as bearings, etc. The hesitation, coughing, sputtering, etc that some experience is an inconvenience at most and certainly a secondary issue to one who is racing and will be pushing his engine to the max in, at most, one lap of getting off the grid. As we know, running with the engine "choked" enrichens the mixture which tends to wash lube oil off the cylinder walls--not a good thing.
BTW I am fortunate in that my car is an easy starter and the return springs positively pull the jets back to normal. I am really not familiar with the "choke" setup of later Big Healeys and perhaps my earlier post was not helpful to the original poster, but it would seem to me that the first step in dealing with the issue is to determine whether the bind is in the carb linkage(s) or the choke cable or both.
steveg
I can't imagine why Welch would suggest driving off immediately since the most important reason to "warm up" an engine--especially a race engine--...
Respectfully would suggest a race engine is a special case, not the same requirements as a street car.
Welch was describing the procedure we were all told to do back in the days of manual-choked cars: get it running then drive it gently for a ways to warm it up. I have to leave my choke on partially for the first mile or so.
In general, starting an engine and driving it immediately--gently until it gets to normal running temperature--is good practice. It works well on modern FI cars where the ECU will run in open loop mode and dump as much fuel as necessary to get smooth running depending on inlet and mass airflow etc. indications (or the default in the fuel delivery map). But, I just rebuilt my BJ8's engine after over 110K miles of following the warmup procedure and there was no evidence of any detrimental effects that could be attributed to this practice. Usually, it only needs 10 minutes or so to get up to 120deg, where it will run well enough to get on the road. FWIW, aircraft engines have a gauge with a green arc; increasing power beyond a high idle necessary for taxi--much less launching at full power--before the needle is in the green arc is considered an absolute no-no. I don't know the reasoning--beyond guessing that the thick, cold oil could stress or even break something--but it's pretty much gospel for piston aircraft.
I may revisit the 'sticky choke' issue; Steve's set screw solution looks quite feasible (I'd considered it before but never got a round tuit). Interestingly, my BN2 doesn't have the sticky choke problem.
RDKeysor
Bronze
My '60 BN7's intake manifold had fittings for the automatic choke Healey used briefly during the time my car was produced. I have neatly sealed those ports as that choke system had been removed by a PO. However, the car also had a C-marked choke knob in the traditional location in the center of the dash. I found it very difficult to work with and disconnected the business end at the carbs, replacing it with an off-the-shelf generic choke pull that ran from under the dash alongside the steering column and connected to the carbs. This worked well, but I wanted to put the "original" choke into service. I didn't do as neat a job as Steve G typically does with his upgrades, but I removed the single-strand wire and the the outer casing and replaced both with a multi-wire pre-lubed bike cable that I managed to attach to the choke knob after considerable effort. It works perfectly and eliminated the jury-rigged choke I had been using. I believe that many of the choke problems develop because of the very stiff single-wire that mine came with. That wire had a loop as it ran from the knob to the carbs, and lubricating it didn't smooth the operation. The bike cable works just fine. Since I have a lot of experience working on road bikes--I own four European bikes--I only wish that it had occurred to me earlier that the bike cable was the answer. I pay attention when Steve offers a solution to Healey issues.
steveg
The solid wires are better for situations where pushing is as important as pulling. If the curves are gentle, they'll work well for the chokes.
My setup depends on the push to return the "choke" levers, but if the "ballpoint pen" return springs work, then the stranded cable would be good.
Michael Oritt
Steve/Bob and All--
While I'll agree that as Steve points the requirements for a race engine are different I take issue with why immediately driving off is the preferred alternative:
"...the latest being Jeremy Welch, of Dennis Welch Performance - that one should “choke” the engine and then drive it immediately to warm it up rather than letting it sit and idle to warm up"
This method may work but I can't see any advantage, other than allowing one to dispense with the warm-up process. Cold fuel/manifolds, does not vaporize well which is the cause of the rough running to begin with.
I will stick to my guns regarding the possibly-deleterious effect of having the mixture enriched for longer than absolutely necessary as the richness unarguably washes oil off of the cylinder walls and also dilutes the oil in the crankcase, causing even more wear in subsequent runs.
BTW I believe the reason that I can release the choke cable early-on and rough running upon start-up is not such an issue on my car is that I have a DW tubular exhaust manifold which sheds more heat and quickly warms up the carbs and intake manifold, resulting in quicker/better oxidation of fuel into the combustion chamber.
Happy starting to all!
CaptRandy
Here is how my are sticking on HD8's First is choke cable all out, second is pushed in, third is pushed in from fully out, forth is after I pushed choke linkage down on the carb and 5 is when I pushed the small piece that never goes in fully on one cable. The cables never fully retract when you push choke button in. Should the ends that stick out be secure in the bar?
Daniel Kaminsky
While we are on this subject, I have the opposite problem. It is very difficult to pull out my BJ8 choke and hold it out while starting. Anyone with any ideas?
Lin
So, I found the email that I had received from Dennis Welch Motorsport concerning the choking process. I provide this without judgement as to whether it is good advice or not, but I do recognize the source as informed. As with most all things, I say "To each his own..." To provide proper context, I have a Welch fast road aluminum head. I had emailed Welch Motorsport to enquirer about what I considered to be a long time for my engine to fully warm up. I was really after issues about water temp, not choking. This is the exact response I received:
Good Morning Linwood,
I have taken some advice from Jeremy Welch for you…
It is normal for all Healeys to need choke for 10 miles or so, this is often surprising to Healey owners.
We do advise that the car is not left idling on the drive to warm up, this is for lubrication reasons. We suggest that the car is started and then driven immediately.
We would also suggest you check that you have an 82 degrees thermostat fitted.
Regards,
Antony
Denis Welch Motorsport
This is just provided as an FYI and is not intended to prolong the discussion :smile:
Lin
"... this is for lubrication reasons"
Assume this is for the cam; I have a DWR gun-drilled cam so hope this mitigates any lubrication issues.
Steve, for your mod what size bicycle cables did you use? Are these a 'specialty' item (all the bike cables I've seen are stranded)?
mountainman SU Choke sticking! Help Triumph 6
Steve P. 1500 Midget; sticking choke Spridgets 6
George Zeck Choke is sticking ??? Spridgets 11
B Sticking throttle and choke knob question Spridgets 9
Todd78d Bugeye choke linkage Spridgets 5
Todd78d Choke Linkage Photo Austin Healey 0
scottkilpatrick TR4/4A Gear oil and choke question Triumph 4
R TR6 TR6 Choke Cable Triumph 11
K TR2/3/3A RE: Pulling the choke knob all the way out....the carb jets should be down how far? Triumph 5
D BT7 Choke Assembly Austin Healey 18
P MGB Zenith water choke gasket needed MG 4
D Choke Cable Length Austin Healey 0
H TR6 1974 tr6 stromberg 175 cd-2 choke Triumph 2
jfarris TR2/3/3A Removing choke cable from dash insert Triumph 3
LAW75 Rubber Tubes for Choke Cable Austin Healey 11
L MGB 1977 MGB will only run on full choke MG 53
SherpaPilot TR6 Choke Assembly Triumph 0
M Choke Linkage Austin Healey 3
D Carb Choke Cable Austin Healey 9
M TR6 1973 TR6 - broken choke cable Triumph 6
TomMull TR2/3/3A Which choke cable Triumph 12
sparkydave Zenith auto choke coming loose Spridgets 2
T TR6 TR6 Choke Cable Lubrication Triumph 5
S BJ8 Choke Cable- How to tighten the nut behind the dash? Austin Healey 6
K TR2/3/3A Couple of choke questions Triumph 1
K Choke cable replacement Austin Healey 1
D AH 300O MK1 Choke Knob Position Austin Healey 5
R Jensen-Healey Choke? Other British Cars 1
F TR2/3/3A Choke Cable Problem Triumph 29
N Enrichener [choke] wire Austin Healey 1
HighAltitudeTR3 TR2/3/3A Choke setting tips? Triumph 7
F TR2/3/3A Choke Triumph 1
edkap2002 TR6 72 tr6 choke cable Triumph 4
Patrick67BJ8 BJ8 Choke Cables Austin Healey 5
TRMark TR4/4A Choke Cable Routing Triumph 3
S TR2/3/3A choke operation from the factory !!!! Triumph 29
S TR2/3/3A Too much fast idle, not enough choke? Triumph 0
BN6_2197 Correct run of the Choke Cable of BN6 Austin Healey 7
S TR4/4A aftermarket choke cable Triumph 3
sparkydave Zenith auto choke coming loose Spridgets 3
K TR4/4A Strombergs...wont idle unless choke pulled out? Triumph 7
UmmYeahOk GT6 I Give Up! Help A Millennial Out [Carb/Choke Related] Triumph 28
M TR2/3/3A Choke Cable Detent Device Triumph 11
Rob Glasgow Choke cable turnion Austin Healey 8
TomMull TR2/3/3A Choke on new to me TR3 Triumph 16
L Choke Mechanism 100/6 Austin Healey 26
trrdster2000 TR6 Double Choke Cable Repair Triumph 0
1 TR6 Tr6 needs choke to run good Triumph 11
rjc157 bn7 electronic choke Austin Healey 0
A 1960 BT7 choke location Austin Healey 8
