I have not tried it yet, but Norman Nock has some springs which are added between the cable and the lever arms, (I am just going to use a hardware spring of appropriate size). Check out their website for parts and you will see how it works.
I had added extra springs connecting the choke enrichment levers from the carbs to the wheel well. It eventually wore out the bushings on the carbs plus it was harder to pull out the choke. This was after I removed the choke enrichment levers from the carbs and cleaned and lubricated it. The original springs work great as long as you keep everything clean and lubricated. Another issue was the choke cables being worn out. I cleaned and lubricated them with graphite and they worked so so. I replaced the choke cables with bike cables and my carb choke works great! Best thing Iāve done for my BJ8 chokes since buying my Healey since 1972. I also purchased springs from BCS to assist in the chokes going full off when choke is released. Several years ago many of us used a couple of ball point pen springs to do the same thing.Common problem with BJ8s. The choke return springs on the carbs are too weak (I guess too strong and you'd have to be The Rock to pull the choke knob). I've tried everything: cleaning and lubing all shafts in the carbs, lubing the cables, etc. The only thing that really works is to rig some extra return springs attached to the enrichment arms on the carbs. I finally gave up; since you usually only need enrichment--SUs don't have 'chokes'--on the first/cold start after I check the oil I leave the bonnet open and start the car, when it's warm enough to run I push the arms down manually.
I can't imagine why Welch would suggest driving off immediately since the most important reason to "warm up" an engine--especially a race engine--...
