Choke Mechanism 100/6
Leew
Hi All
There are some bits missing from my choke mechanism....see photos
It's extremely difficult to work out from the AH catalogue what parts I need
Does anyone have a picture of a completed mechanism on the car so I can get a better idea
Alternatively a list of parts I can order
Ta....
L
Leew
Thanks Andrea, really helpful
I've checked to AH spares website and they show these parts....not quite sure if they are correct, especially the stirrup kit?
The "stirrup kit" is for the earliest Longbridge integral manifold 6-cylinder engines, not for the ones with a separate, detachable aluminum manifold with HD-6 carbs like your pictures show (as seen below).
Andre's pictures show the missing parts for your setup, including his last picture that shows the connecting rod between the two (2) carb jet levers; item #123 in the Moss Motors picture below:
https://www.mossmotors.com/Shop/ViewProducts.aspx?PlateIndexID=28864
Longbridge choke linkage__less actuating cable__shown below:
British_Recovery
Bronze
Hi,
If you already have the correct cable, and the connecting rod is in place, you need a "trunnion assembly - part 378-618" and "trunnion and screw - part 378-648" in the Moss catalog. See their Engine and Performance section, and then "controls".
Good luck, Bob
L
Leew
Is there a link to the parts I need from a UK supplier...
It's OK, I've found Moss Europe
Lee
healey106
Randy - thanks for sharing the photos of the Longbridge BN4 engine, with the heat shield painted the same color as the engine. However per the Concours Guide this heat shield should be painted red and not the engine color. Does anyone have any experience with the red heat shield on the Longbridge BN4?
thanks for sharing:driving:
blueskies
I made a heat shield for my Longbridge BN4 not long ago. Here is a pic, before the red paint went on.
andrea
Red, probably was the right on 100/6 Longbridge at Abington ,on my opinion, it went to engine colors
It's been some years now, and I'm not able to produce irrefutable proof__at least without accessing some old hard drives__but I'm thinking my color choice for the heatshield was based on finding underlying layers of paint in the engine color shown.
I was very mindful of the engine color itself, as I've seen Longbridge engines way back when that were a dark blue, and I wanted to do this one correct. Again, the underlying remnants of paint told the story, and I believe the owner was doing his own research based on VIN, and we arrived at the same conclusion.
healey106
Randy - thanks for sharing, I just wish there could be some additional insight provided in the current concours guide which states that the heat shield has to be red. I must agree in all the Longbridge engines over the years I have never seen a red heat shield, but then again I am not a concours expert.:driving:
healeyblue
Yes I believe the green heatshield is correct for the engine Randy did for us. I think the longbridge cars are the most misunderstood cars of all the big healeys, even more than the 100M.
L
Leew
I am still faffing around trying to understand this choke / start lever mechanism
The picture from Andrea shows a square piece that attaches to the bottom leaver as well as taking the choke cable.....see photo
I cannot find that listed in any spares catalogue, Moss. AH Spares, SC Parts, SU Carbs.
Is it home made?
British_Recovery
Bronze
The cable comes in from the top, the casing being retained by 378-618. The inner cable continues down to 378-648, which mounts to the lower lever. I have added an additional return spring on the lower lever to return it to running position when the choke cable is returned.
Sal36
Hi everyone.
I have studied this entire thread and still can't figure out if the choke outer casing is supposed to be secured firmly inside the choke cable bracket (#115 below). If the outer cable is supposed to be secure in the bracket can anyone tell me how the choke cable outer outer casing is secured in the choke cable bracket using the choke cable trunnion (#100 below).
Sal
Sal36
Sal
steveg
Sal - This should do it. The drill represents the cable housing. Tightening the nut clamps the barrel onto the cable housing while still letting it rotate freely in the bracket hole. These are stock parts.
screenshot.2612.jpg screenshot.2613.jpg screenshot.2614.jpg screenshot.2615.jpg
Todd78d Bugeye choke linkage Spridgets 5
Todd78d Choke Linkage Photo Austin Healey 0
scottkilpatrick TR4/4A Gear oil and choke question Triumph 4
R TR6 TR6 Choke Cable Triumph 11
K TR2/3/3A RE: Pulling the choke knob all the way out....the carb jets should be down how far? Triumph 5
D BT7 Choke Assembly Austin Healey 18
P MGB Zenith water choke gasket needed MG 4
D Choke Cable Length Austin Healey 0
H TR6 1974 tr6 stromberg 175 cd-2 choke Triumph 2
jfarris TR2/3/3A Removing choke cable from dash insert Triumph 3
LAW75 Rubber Tubes for Choke Cable Austin Healey 11
L MGB 1977 MGB will only run on full choke MG 53
SherpaPilot TR6 Choke Assembly Triumph 0
M Choke Linkage Austin Healey 3
D Carb Choke Cable Austin Healey 9
M TR6 1973 TR6 - broken choke cable Triumph 6
TomMull TR2/3/3A Which choke cable Triumph 12
sparkydave Zenith auto choke coming loose Spridgets 2
T TR6 TR6 Choke Cable Lubrication Triumph 5
S BJ8 Choke Cable- How to tighten the nut behind the dash? Austin Healey 6
K TR2/3/3A Couple of choke questions Triumph 1
K Choke cable replacement Austin Healey 1
D AH 300O MK1 Choke Knob Position Austin Healey 5
R Jensen-Healey Choke? Other British Cars 1
F TR2/3/3A Choke Cable Problem Triumph 29
F Choke sticking Austin Healey 22
N Enrichener [choke] wire Austin Healey 1
HighAltitudeTR3 TR2/3/3A Choke setting tips? Triumph 7
F TR2/3/3A Choke Triumph 1
edkap2002 TR6 72 tr6 choke cable Triumph 4
Patrick67BJ8 BJ8 Choke Cables Austin Healey 5
TRMark TR4/4A Choke Cable Routing Triumph 3
S TR2/3/3A choke operation from the factory !!!! Triumph 29
S TR2/3/3A Too much fast idle, not enough choke? Triumph 0
BN6_2197 Correct run of the Choke Cable of BN6 Austin Healey 7
S TR4/4A aftermarket choke cable Triumph 3
sparkydave Zenith auto choke coming loose Spridgets 3
K TR4/4A Strombergs...wont idle unless choke pulled out? Triumph 7
UmmYeahOk GT6 I Give Up! Help A Millennial Out [Carb/Choke Related] Triumph 28
M TR2/3/3A Choke Cable Detent Device Triumph 11
Rob Glasgow Choke cable turnion Austin Healey 8
TomMull TR2/3/3A Choke on new to me TR3 Triumph 16
trrdster2000 TR6 Double Choke Cable Repair Triumph 0
1 TR6 Tr6 needs choke to run good Triumph 11
rjc157 bn7 electronic choke Austin Healey 0
A 1960 BT7 choke location Austin Healey 8
E T-Series MG TD choke cable MG 2
O Electric choke problem. Jaguar 0
T TR2/3/3A TR3 choke cable connection help needed Triumph 21
S TR4/4A choke linkage Triumph 2
