So today I replaced every seal, spring, and washer in the carb jet assemblies (H6). Jets now move smoothly up and down with only light hand pressure on the levers.
Replaced the entire choke cable assembly with the Moss original equipment style. Also got the correct o/e choke knob - has small hole for the lock pin.
All in place - ready to add the knob.
Knob slides onto shaft, but the "lock" pin doesn't drop down. Remove the knob, check for free action in the pin and spring, replace knob. Same problem. I see the pin through the hole, but it doesn't "drop".
Removed knob again. Found that the internal spring wasn't pushing the pin down. Lightly increased the spring bend, replaced the knob ... and as I was pushing the knob back, the spring twanged out, broken at the bend.
Replaced the spring with the one from the old cable assembly. Same problem - knob goes fully back (with or without the o-ring) and stops solid, but the pin doesn't drop.
Pulled the knob back off, checked that the pin had enough room to move up and back, replaced the knob, and voila! The knob shaft split.
Tried the original knob (easy to remove from the old cable by pushing up on that original lock pin). Original knob doesn't quite travel back far enough to clear the pin - so pin won't drop even when pushing knob back with a *lot* of force as far as possible.
Is there some secret to this? All the other dash knobs easily pull off and on with the pin working fine. New cable assembly - and the knob (yes, the correct one) won't lock onto the shaft.
Trade secrets exchanged anyone? The thought of paying $10 for shipping another $5 knob isn't pleasing me right now. I shudder to think I may have a "crypt choke".
Tom
Tom
