AussieMGB
Hello; I'm after some advice/general discussion on the twin SU HS4 set up.
Is it common to have only the rear carbi connected to the choke; no connection rod to the front one. Throttle connection is fine of course however, with my limited understanding, I thought it was best to have both carbs choked for the cold starts because of splutting and potential damage to the engine
Admittantly, the choke is only required for about 5 minutes or so however, it's not right in my mind (as are many things in my mind).
As I see it, I have two choices; the easy and the not so easy: Easy Rule 1 - if it works, don't play with working carburettors. Rule 2 - obey rule 1
The more difficult: connect the chokes with a choke connecting rod. Should I go down this path, has anyone had success with the carbs in situ; i'd rather not pull the whole thing apart.
I'm thinking, all I need to do is connect the choke mechanism so they both operate together, how can I get a rod connected between them ( I can get a rod from rimmer Bros for a triumph 1500) . I've got a picture, perhaps this might provide food for some thought.
