TR4/4A Choke Cable Routing
TRMark
Bronze
I installed HS6's and the later manifold on my originally H6 equipped 63TR4. The later carb has much different choke linkage. Where do I route the cable through the firewall? Can you post up a picture?
I also use the HS6 carbs on my TR4's. I use a double cable for the chokes. I use the grommet directly above the heater hoses. The long cable is to long and I routed it under the heater valve. The short cable barely makes it over the top of the carb and into where it belongs.
Thanks guys. Yup,its the grommet above the heater hose. My carb setup uses a single cable, there is a linkage between the carbs. I did find the thread with the pictures I needed.
