Nelson
It has only been 36 years since I took my engine apart but I am having a hard time remembering all the connections. I am having a problem with the choke cable connection at the carbs - I think. I have a pair of H4's so my setup might be different than the usual SU's found on other 948's. The choke cable passes through a cross drilled bolt on a bracket between the two carbs but I see no way that it can be secured to that bolt. There is just a hole to pass through. Is the cable simply secured by the nut that fastens it to the dashboard? I have the connections for the carb choke linkage hooked up. For the moment I just hope to get the engine running next week for the first time since 1973. The dashboard is not installed as the car is not quite ready to get painted yet.
