G
Anyone ever checked their shock absorber fluid? I looked in my MG Midget repair manual and the only thing I can find on the shock absorbers is how to R&R (remove & replace) them. Do you remove the screw on the top side of the shock to check the fluid level? Should fluid come out? How do you determine if the fluid is low? I have been checking the front suspension, steering, & brakes on my 76 Midget (the former owner replaced almost everything) to ensure that everything is ok but I would also like to check and top off the shock fluid. Any suggestions, procedures, or help is appreciated. Thanks.
