Check Valve for Reservac Tank - MK2
Lin
Hello all,
In the restoration process, I am now working on the reservac tank and stoneguard assembly. The original check valve cleaned up nicely, but how do I know if it is functioning properly? A new one doesn't cost much but I am not into spending money on new parts if the originals are fine. Do these things go bad? Is there a test I can do?
Thanks,
Lin
Lin Rose
1959 AN5 Bugeye - pure driving enjoyment, go-kart with a body.
1960 BT7 "The Bloody Beast" - owned since 1971, my first car and still have it!
1964 Jag MKII - current project
Yeah, they go bad. I check them orally. If they don't pull a suction in one direction, free in the other, replace it.
The trick really is to get it hooked up correctly. Again, oral checking, so vacuum from inlet goes directly to tank, shuts off when you pressurize (orally) the line from the inlet manifold.
