The stock BJ8 cam's are actually a 3/4 race profile(I've read this several times), and will not be as smooth as a stock 100-6 or early 3000's idle.NIB said:Is there some simple way to check if you have the stock camshaft in the engine (BJ8)?
Superwrench said:Yes Just put a [Dial indicator] on the " VALVE " side of rocker and turn engine over with a wrench. It should have .368 inch lift.
If memory serves me, the BJ8 cam has a 252° total duration.BoyRacer said:Secondly, the BJ8 camshaft is far from a 3/4 race grind. It idles just as smooth as any earlier 6 cylinder engine.
Yes, the T-3-6 has a 268° duration. The T-4-6 grind is a little more radical at 286°.BoyRacer said:An Iskenderian grind, the T-3-6, is truly a 3/4 race cam and it's lobe lift is .289 - .290.
Kind of easy to tell if it's an Isky cam, if you happen to have the transmission, clutch/flywheel and backplate out...GregW said:Yes, the T-3-6 has a 268° duration. The T-4-6 grind is a little more radical at 286°.BoyRacer said:An Iskenderian grind, the T-3-6, is truly a 3/4 race cam and it's lobe lift is .289 - .290.
Do you have an Isky cam in your car?
BoyRacer said:Not only is the Isky T-3-6 cam totally streetable, it is one Big Stick for our size of motor. I have used the Isky T-3-6 in a street car and in my race car in the past. I use a different grind right now, but still in the 260-270 degree duration. I make 230 Hp at 5900 RPM and have over 200 ft lbs of torque from 3000 RPM to over 6000 RPM.
If you use a "bigger" cam, that is, one with longer duration (like the Isky T-4-6), you will kill the engine. Which means, loss of torque and it will push your peak power band into the stratosphere (7000 RPM).
The simple truth is cubic inches will kill a cam. We have small engines (3000 cc) or approximately 165 cubic inches. A cam with 268 degrees overlap is HUGE with our engine. If you put the same duration cam in a Chevy, or Ford, or Chrysler V8 351 or 360ci, the cam is an absolute wimp. A cam with BIG duration works in BIG motors, not vice versa.
I love torque! It's the primary reason (but not the only reason) why my daily driver is an M Rdstr, and not a Boxster!BoyRacer said:If I correctly remember that old saying: "Torque wins races - horsepower sells cars".
