glemon
Having read in various places that the trailing arm mounts for the IRS TR4A-6 can be a weak spot, especially when weakened by corrosion and stress over time, and being under the car anyway, and fabricating pieces to fix my cracked differential support, I thought I might as well do some work on the trailing arm mounts. Below are pics of what I came up with, the 1/8 steel I put in should spread the load over a much larger area than the little washers that were there before. Included are before and after pictures as well as one of my simply fabricated pieces.
