Chassis ID number tag missing
JDstr4a
no chassis tag. Any other way to get it?
JD
HerronScott
You could order a BMIHT certificate for your car. I also recall that when I restored my TR4A I found a number in the driver's side rear inner wheel well which looked similar to a chassis number. I don't know if it's supposed to match the chassis number on the tag though. I'd have to check on my second one as I replaced the frame and inner tub on my original TR4A so they would not match at this point.
Scott
J
JDstr4a
Thanks. took a quick look and didn't see anything but spider sacks from the barn. i'll make a note on my list to check better when I get her up on stands and the wheels off.
Do you know if alot of owners do the BMHIT thing?
JD
Andrew Mace
Just so we're all on the same page: is it the Commission number plate that you're missing...the one that would show "CTC58489L" along with the paint and trim code numbers?
It would look something like this one:
J
JDstr4a
I have the commission tag, though it's in pretty rough shape. I thought there was supposed to be a chassis tag on the opposite side, which is pretty covered with surface rust, though there seems to be a rivet left over.
JD
HerronScott
JD,
Yes there should be a chassis tag on the passenger side.
Scott
HerronScott
JD
The number in the wheel well appeared to be stamped on a small welded-on plate and was under the undercoating so it might be hard to find.
Oh and regarding the BMHIT certificate, I don't know if a lot of owners do it but I did it for my cars.
Scott
J
JDstr4a
I've been looking at that. Did you use the commission number where it said Car/Chassis number?
JD
HerronScott
JD,
Yes, I did mine using the commmission number and here's the information fields that are provided on it.
1. Make & Model
2. Car/Chassis Number
3. Engine Number
4. Body Number
5. Specification
6. Colour: a) exterior, b) trim, c) hood (top)
7. Date of Build
8. Date of Despatch
9. Destination (Dealer)
10. Other Numbers (where recorded)
11. Details of Factory Fitted Equipment
12. Other Information
13. Issued to
14. Date of Issue
15. Signature of Archivist
Note that they do not always have all the information on every car. One of my TR4A's had much more information including key numbers, hood color, date it shipped, destination and what ship it was shipped on while the other did not have that information available.
So on the one with minimal information, I was able to confirm the chassis and engine were original, the day it was built and that it originally came with radial tires on wire wheels (which were gone when I bought it). So it's up to you whether that's worth the cost if that's all you get.
Scott
J
JDstr4a
Thanks Scott, without the chassis tag, I think it will help to have the certificate for documentation.
JD
Geo Hahn
If this is the tag you mean (photo is a TR4, not 4A) then (once you have the number) I think you could make one fairly easily as it is just stamped numbers on an unpainted aluminum blank.
Let me know if a detailed photo would be helpful.
Guido36 Chassis Number Issue Austin Healey 11
lbcspinners BJ8 chassis number ending with suffix "G" [??] on BaT Austin Healey 11
E Jag xke chassis number 885616 Jaguar 1
AH67 100M Chassis number BN2L230735 Austin Healey 4
T TR2/3/3A TR3a Chassis Number Triumph 20
J Chassis Number on Shock Tower Austin Healey 15
S diffuculty in obtaining chassis number for bj8 Austin Healey 9
H BN1 Chassis Number Plate Austin Healey 6
A chassis number Austin Healey 2
A BN2 Chassis Alignment Austin Healey 8
RJS TR4/4A Chassis Buffeting(?) Triumph 10
apbos The next rabbit hole. Help ID the chassis. Racing 27
apbos Help Identify this car chassis Racing 20
5 MGA Body and Chassis Separation? MG 2
BoyRacer Silver Healey - Chassis Color? Austin Healey 17
HealeyPassion Finally, paint on chassis Austin Healey 17
apbos TR5/TR250 TR250 rolling chassis and body for sale Triumph 3
Pep Daimler SP250 A-spec vs B-spec chassis Other British Cars 9
M TR6 TR5/6 Engine Mount/Chassis Brackets Assistance Please. Triumph 2
D Wanted: Healey 3000 MkIII body and chassis Austin Healey Classifieds 0
Editor_Reid Healey 100 Chassis Dimensions Austin Healey 5
F TR2/3/3A back half to chassis questions Triumph 105
M Mounting BJ8 Chassis on Rotisserie Austin Healey 8
J Wanted WTB Triumph TR6 Body/ Rolling Chassis Triumph Classifieds 0
B Chassis Suppliers Austin Healey 0
J Wanted MK VII/VIII/IX rolling chassis with or without drivetrain Jaguar Classifieds 2
J Wanted Jag MK VII/VIII/IX rolling chassis with or without drivetrain Other British Classifieds 1
J Wanted TR3/4 rolling chassis Triumph Classifieds 2
J Wanted TR3 or TR4 rolling chassis Other British Classifieds 3
C TR2/3/3A TR2 Chassis Clips Triumph 4
B MGA Mystery MGA chassis part MG 3
V TR2/3/3A TR3A Chassis restoration Triumph 8
T TR2/3/3A Chassis paint color Triumph 10
BoyRacer Rig for storing chassis on its side Austin Healey 8
M TR4/4A Reducing rear chassis flex. Triumph 3
red57 Metal prep of chassis after repairs and shot blasting Austin Healey 5
B General Tech Prime over Chassis Saver? MG 3
TomMull Numbers re Chassis project Lotus 4
crya Current go-to source for VIN/Chassis Repro Plates? Austin Healey 8
TomMull CHASSIS SHIPPING Lotus Elan Plus 2 Lotus 22
P TR2/3/3A Chassis paint questions Triumph 8
F TR2/3/3A 1960 TR3A starting chassis work Triumph 81
M TR4/4A Reducing Chassis Flex on TR4A IRS Triumph 2
C Chassis plate screwsize Austin Healey 6
aero3113 BN2 Front Chassis Rail Austin Healey 6
Jake For Sale FS: BN1/BN2 Kilmartin Chassis Repair Parts, New Austin Healey Classifieds 2
K How would a new-chassis car be registered? Austin Healey 15
B GT6 Chassis color Triumph 4
PeterK TR2/3/3A Ebay rolling Devin body moded chassis - with O/D Triumph 1
