chassis black - which black
Hoghead
The restoration guide gives black as the colour for the suspension components
Gloss, flat, or something in between
5
57_BN4
Eastwood Extreme Chassis Black in a spraycan is pretty hard to beat. I used gloss which tends to dull to satin with age. They do a satin as well which I used on the heater box.
It wrinkles up if you spray on too many coats, I noticed that on the brake backing plates where it was hard to get even coverage without over-painting some areas. Minor issue really.
Andy.
H
Hoghead
Done in one coat of POR 15 gloss now but is it not UV stable and a second coat of UV stable paint is recommended.
Are you saying that satin is correct?
5
57_BN4
I'd say there is no 'correct' gloss level, more dependent on what large drum of low cost black liquid the factory could get their hands on at the time. Anywhere between satin and gloss will look much the same after a few months use given that there aren't any large flat areas on the suspension components.
What ruins the originality theme for me is seeing how many people paint each part separately and then assemble them with nice shiny re-plated fasteners. It is far more likely that the factory assembled the bigger components (EG the back axle) then hosed them all over with black in a somewhat uncaring fashion.
There will no doubt be some variation in original paint type because some OTS parts would probably have arrived at the factory already painted such as the dampers. The rear dampers on my car were assembled unpainted then the arms were painted black which left overspray on the aluminum housings. The housings were definitely not painted intentionally and that is how I will redo them.
Andy.
PAUL161
I use Martin Senior Tuff Coat in semi gloss for chassis. Is it correct? Good question, but it looks great! I just try to stay away from high gloss for chassis. No paint today will match perfectly, the paint they used 40/50/60 years ago.PJ
55 TF Semi gloss chassis black
Semi gloss black
Richard Dickinson
I have used Eastwood Extreme Chassis Black both in an HVLP gun and a spray can. Also used Rustoleum High Performance Gloss, end result it all looks about the same. I used a lot of the original bolts and screws so the spray can works well to touch up after assembly.
A BN2 Chassis Alignment Austin Healey 8
RJS TR4/4A Chassis Buffeting(?) Triumph 10
apbos The next rabbit hole. Help ID the chassis. Racing 27
apbos Help Identify this car chassis Racing 20
5 MGA Body and Chassis Separation? MG 2
BoyRacer Silver Healey - Chassis Color? Austin Healey 17
HealeyPassion Finally, paint on chassis Austin Healey 17
apbos TR5/TR250 TR250 rolling chassis and body for sale Triumph 3
Pep Daimler SP250 A-spec vs B-spec chassis Other British Cars 9
M TR6 TR5/6 Engine Mount/Chassis Brackets Assistance Please. Triumph 2
D Wanted: Healey 3000 MkIII body and chassis Austin Healey Classifieds 0
Guido36 Chassis Number Issue Austin Healey 11
Editor_Reid Healey 100 Chassis Dimensions Austin Healey 5
F TR2/3/3A back half to chassis questions Triumph 105
M Mounting BJ8 Chassis on Rotisserie Austin Healey 8
J Wanted WTB Triumph TR6 Body/ Rolling Chassis Triumph Classifieds 0
lbcspinners BJ8 chassis number ending with suffix "G" [??] on BaT Austin Healey 11
B Chassis Suppliers Austin Healey 0
J Wanted MK VII/VIII/IX rolling chassis with or without drivetrain Jaguar Classifieds 2
J Wanted Jag MK VII/VIII/IX rolling chassis with or without drivetrain Other British Classifieds 1
J Wanted TR3/4 rolling chassis Triumph Classifieds 2
J Wanted TR3 or TR4 rolling chassis Other British Classifieds 3
C TR2/3/3A TR2 Chassis Clips Triumph 4
B MGA Mystery MGA chassis part MG 3
V TR2/3/3A TR3A Chassis restoration Triumph 8
T TR2/3/3A Chassis paint color Triumph 10
BoyRacer Rig for storing chassis on its side Austin Healey 8
M TR4/4A Reducing rear chassis flex. Triumph 3
red57 Metal prep of chassis after repairs and shot blasting Austin Healey 5
B General Tech Prime over Chassis Saver? MG 3
TomMull Numbers re Chassis project Lotus 4
crya Current go-to source for VIN/Chassis Repro Plates? Austin Healey 8
TomMull CHASSIS SHIPPING Lotus Elan Plus 2 Lotus 22
P TR2/3/3A Chassis paint questions Triumph 8
F TR2/3/3A 1960 TR3A starting chassis work Triumph 81
M TR4/4A Reducing Chassis Flex on TR4A IRS Triumph 2
C Chassis plate screwsize Austin Healey 6
aero3113 BN2 Front Chassis Rail Austin Healey 6
Jake For Sale FS: BN1/BN2 Kilmartin Chassis Repair Parts, New Austin Healey Classifieds 2
K How would a new-chassis car be registered? Austin Healey 15
B GT6 Chassis color Triumph 4
PeterK TR2/3/3A Ebay rolling Devin body moded chassis - with O/D Triumph 1
P BN1 Rear Chassis-to-Shroud Extensions Austin Healey 1
Brinkerhoff TR4/4A Straightening a TR4A IRS chassis Triumph 15
BoyRacer weight of bare Healey chassis Austin Healey 8
I Chassis rotisserie..? Austin Healey 10
A Chassis front 'H-section' Mk1 Spridgets 5
S Austin Healey 3000 BT7 1960 VIN chassis STAMP location Austin Healey 9
madhouse need new chassis Austin Healey 15
