paulsherman
When I change to front disc. brakes, what else should/must be changed. Master Cyl., push rods or what?
Thank you
Thank you
Talonaer said:Do all rib case boxes use a 3/4 slave?
Thats true about the rubber hose, I had forgotten that. And you're right...The clutch pedal isn't hard to push.Billm said:The ribcase slave (1.0") will give you a softer clutch peddle than the smoothcase slave (7/8"). If the peddle is too hard to push then it will help but I doubt that it is too hard to push. Also of you change the slave you will have to add the rubber whip connector hose which will not be so fun to add.
BillM
Thanks GerardGerard said:As I mentioned above, the introduction of the ribcase with the 1098 continued to use the 7/8" slave until the 1275 was introduced. Both bores of the 3/4" master cylinder from an early disc brake car are 3/4" and are a correct match with the 7/8" slave.
