<div class="ubbcode-block"><div class="ubbcode-header">Quote:]By all means, check with whoever you trust, Paul. I'm just repeating what I've heard from the likes of Kas Kastner and Greg Solow.[/QUOTE]
Randall, somehow we always seem to agree to disagree amicably, which is a good thing. And I never meant to imply that I didn't trust your judgment, which I think you know. In this case however, I have to bow to your comments and acknowledge your statements as more correct than mine. In speaking to several cam manufacturers, the cams are not "fully hardened" in the production process, nor should they be (as I was incorrectly assuming). A good cam is in the RC52-55 range. The problem is that to test them, ruins the surface that you are testing. While none would readily state the break in process contributes to a "work hardening" of the cam lobe surface, there was enough of your answer to be correct over what I had thought was the correct process. There answers seem to confirm that the lobe surfaces are considered polished and that the parts mate together as the break in.
An interesting point was that everyone points to the oil (lack of zinc) as an issue, but they are also very concerned about the use of hardened lifters in the RC65 and up range. Several felt that these are too hard and combined with the very slippery oils in use today, which do not allow the lifter to rotate on a flat tappet cam, an increase in lobe wear will be inevitable, sooner, rather than later in most cases.
As Bill mentioned, the correct valve spring pressure and the angles created a higher lift all contribute to a more accelerated wear situation than on a softer stock grind.
So again, I'm pretty much back where I started from. I think that it's a crap shoot no matter who you chose or what you end up doing, even if you match everything and do your due diligence about oil, additives and valve springs.
