Richard Dickinson said:I bought a set of non-Girling master cylinders from Moss (probably a mistake) but the instructions that came with them said the warranty is void if silicone fluid is used. Why would this be?
Brake fluid:
Using Teflon tape on industrial hydraulic tube connections is a no-no, and I'll just leave it at that... :wink:
This is the brake light pressure switch on the last BJ8 I worked on; please note the copper sealing washer seated on the mating taper surfaces. I expect getting a correct replacement is nearly impossible, so if yours is still fitted with one, DON'T LOSE IT! A copper sealing ring is easily annealed, lending itself to a lifetime of re-installations, if need be.
