Bill Yes bearings will be marked for size and quite often brand as well(Vandervell,Glacier and a host of others)
That's what I like about the Standard engine in the TR cars, bottem end is a relatively easy rebuild in the car, often called an "in frame" rebuild as is done with large diesel trucks. In fact the engine can be redone in it's entirety with the block left in the car,providing bore measurements are within spec.for taper etc.and no scoring is present,and the crank shaft is good.
The first cap I pull I mic the old shells and the new shells to see what differences in measurement are present.If it is more than .001, I would measure with plasti gauge to make sure it's not too tight.
The hardest bearing to replace is the front one as the timing chain keeps tension on the crank,if the chain is any good.I have tapped a small block of wood between the water pump pulley and crank pulley pushing the crank down a thou or two.Then using the new shell, push the old one round the top half of the crank until you can grab it.I try to stay away from using screwdrivers etc. as the crank is easily burred by the slip of a tool etc.
Make sure you apply bearing assembly lube to bearing face.Keep the back side clean.(the side facing the block or cap)
Similar process with rod bearings.I cut 3inch lengths of fuel line and slip these over rod bolts so that they don't damage the crank if they slide of the journal as you move them, or the crank around to get at the top shell.
The last in frame i did cost about 225.00 incl.tri metal rod and mains,thrust washers,lower gasket set,relief valve and spring and new oil pump.All parts came from British Parts Northwest.
However if your not comfortable doing this yourself, get somebody to help you as it does get a little spendy if it fails.
Warranty is hard to claim for, if work is done by oneself
