Ceramic Coating Exhaust Parts
1965_MGB
I just got back my header and manifold from being ceramic coated by a local guy here in S. Florida, and I can't believe the difference.
I found the guy on another board (not MG), and after talking to him for a while about his process, I sent him my stuff and I am impressed.
He coats the inside as well as the outside of the stuff with a coating that is resistant to 2K degrees. I was kind of skeptical of this, but I had a look at his car which has the same coating, and I was able to put my hand on the exhaust manifold with the car running.
The coating he put on can be polished, as he did with my stuff.
I have posted a pic of after coating to give you an idea of how good it looks.
I forgot, if anyone is interested, his website is www.braincoating.com.
He is in Wellington Fla. Not too far from me. His prices are pretty good as well. He did both my header and cast manifold for $225.
I sent my headers to Jet Hot also. Very happy, took about a week to get them back.
Ok, I ask because I do not know, how does this method of ceramic coating compare to the factory ceramic coating of my Mk1 Jag?
I believe the jags are porcelain coated, at least on the E types. This looks like a very nice painted finish and does not flake like porcelain. I have an E type with ceramic headers and they have not discolored at all.
Ahhh...I think you are right...porcelain rather than ceramic. And I understand you can no longer get the porcelain coating because it uses lead...?
I might be wrong, but I heard that the porcelain coating uses a lead based primer on the part to be coated for adhesion. With modern technology, they might use another environment friendly primer. I would hope this to be true as some antique cars had porcelain coated exhaust manifolds and for concourse, 100 point restoration, this is a must.
I just had the exhaust manifold of the '63 Midget I'm restoring ceramic coated...boy, is it pretty!
I have to agree with Tony. Both my header and manifold look better than they ever have. Nothing like a silver finish that is going to be permanent. I could have gone with black, but I thought the silver would look better.
You can sorta see my ceramic coated exhaust manifold in this photo:
Yep! Its supposed to be painted.
Here's my Prefect exhaust ceramic coated inside and out.
I think it must because it definately makes the exhaust manifold or header run cooler.
Ceramic coating a heat shield probably won't do much good. You may only need to paint in with a high-temp spray paint.
The ceramic coating keeps the exhaust manifold from giving off heat in the first place.
