Cd150 Carb bolt size
neilh
Can anyone tell me the bolt size for the bolt that holds the heat mass water jacket onto the heat mass on the autochoke on a Zenith/Stromberg CD150 - 79 midget?
Moss and VB are out of stock, and i sheared it off!
Cheers
Neil
Neil, I've got a complete CD150 on the shelf, from having moved to a Weber.
If you take me a picture or find a digram, I'm happy to pull it & send. I have no intention of going back to the Z-S.
Ulf, thanks, it is - I also need a #34, that cracked when the bolt head sheared off!
If Duncan can't help you out, I probably can - Or you may want to take this opportunity to go for a manual choke - which is why I don't need those any longer
Yes, I should have both. Drop me an IM with your address, if you still need them. As JP says tho, you may want to seriously consider upgrading to a manual choke. The water chokes are notoriously difficult and inefficient.
