Caving In [5-speed conversion for BN2]
roscoe
For a variety of reasons, not the least of which is that I ain't gettin' any younger and I'm not sure how much longer I can " do it all myself" in terms of the bigger jobs, I have made the plunge to put a Toyota 5 speed in my BN2. I've had a few gearbox issues and although I can likley fix them, the long term prognosis is that parts are hard to get. By parts, I mean wrists, shoulders and back parts that I unfortunately can't fix myself. Also, I've been trying to get my wife to drive since I put it on the road. She is 5 foot 1 and has a hard time being comfortable with the mechanical clutch. Having the hydraulics and not having to twiddle the OD might make it more attractive for her. If I create a monster and she starts to think of it as "her car", well that's OK too.
Before anyone asks, I'm going to keep the original gearbox and OD and leave the bits in the engine bay and the dash switch for the person who gets the lot when I leave this mortal coil. Maybe I'll really miss flipping the OD on and off.
I have managed to find a very nice W58 gearbox and have the Smitty/Delaney kit on the way. As Pete Delaney recommended, I am going to put in a BJ8 diaphram clutch and lighten the flywheel a bit. I know it isn't rocket surgery to do the latter, but in a way it is, in that the physics of what is being done are beyond my intuitive abilities. So, I will ask the forum to suggest by how much to lighten said flywheel? I do not rally or race and my enginge almost never sees more than 3200 rpm. Yeah, I know I'm missing some big fun.
As with all of my mechanical endeavors I strive to do no harm and I know the flywheel is on there for a good reason but I have no idea if the original weight was specifically designed or someone just said " mate, don't forget to put a heavy flywheel on there". I'll have it balanced, with the new clutch if possible and I know that ideally you balance the rotating components, including the crank, slap a real balancer on the front in place of the rubber band and so on. Not going to go that far and I have previously installed a rear crank seal kit. As always, thanks for your input.
Jon
steveg
Bob McElwee
Re: Caving in
Jon, to satisfy your desire to use the OD switch, occasionally filp it when you shift in/out fifth gear!
John Turney
Re: Caving in
When I moved my OD switch to the shift knob, I put the headlight dip switch in its place and made a dead pedal for my left foot when not using the clutch.
roscoe
roscoe
Re: Caving in
Thanks Steve. I have read Michael's article and it is a very good piece. I'll wait and see how the kit goes together but I'll contact Dave Dreamer as I'm all in favor of making things out of aluminum angle. With all the scrap I have I won't be surprised if I have something suitable that bolts up.
Yes, it'll be hard to not blip the throttle in 3rd gear slowing for a stop, might as well flip the switch too. I was also trying to decide what sort of cool thing I could wire to that switch. Perhaps a nitrous oxide injection system or some wheel well LEDs. I used to work for a guy who was pretty much of an unpleasant sort. He asked me to install an a switch in his RX7 that would allow him to turn on his back up lights to make people who were tailgating him back off. Kind of a nasty trick and likley unsafe at night. Oh, wait, no back up lights....
roscoe
roscoe
Re: Caving in
I like the dip switch idea. I do have to say that having one car with the foot switch takes me back to when everyone had a foot switch. I have good memories of that place.
steveg
Re: Caving in
pictures courtesy Dave Deamer, who just installed the 5-speed on his BN1.
Stock bracket:
Dave's bracket under construction:
roscoe
roscoe
Steve, thanks for posting those. I'm sure it will make sense when I have the kit in front of me.
Michael Oritt
Though the present mis/malalignment of the clutch linkage in my car's setup has never given a moment's pause since first installation I will certainly opt for Deamer's upgrade if for no other reason than it looks so nice.
Jon, I cannot tell you how much to lighten the flywheel but you are on the right track with all of your proposed changes. While you're at it think about either putting in a remote hose or create a small access door in the vertical panel to make clutch bleeding easier. I replaced the OD switch with a large red light tied to a low oil pressure switch. And start sticking your foot in it--there is a whole world of performance and excitement above 4K rpm's.
BoyRacer
The answer to how light to go with your flywheel is: lighten it as much as you can. The stock flywheels for the 6 cylinder cars vary slightly between 28 and 29 pounds. Don't know the stock weight of the 100 flywheels are but they are also too heavy. The trick to lightening as much as possible is in addition to shaving material off the back side but to also scallop out material on the face, or front side, around and to the inside of the circle of the pressure plate mounting bolts. Again, with a 6 cylinder flywheel, you would be lucky to shave off seven pounds and that is still a heavy flywheel. A lightened flywheel will feel like you have 10 more horsepower. You will love it!
roscoe
roscoe
Thanks so much for the information. I'll report back but it will be a while. I might wait until rainy season to do the work as right now my gearbox is pretty happy.
roscoe
roscoe
One more question ( for now). The 100 flywheel has two dowel pins that are 180 degrees apart. The BJ8 clutch housing is a 3 dowl pin assembly and I assume the pins are 120 degrees apart. So I'm assuming I will have to drill 3 new holes or at least two holes using one of the original ones, in the flywheel. Can anyone tell me if this is correct? Are the dowel pins on the BJ8 flywheel evenly spaced? Are the dowel pins threaded or are they a press fit?
steveg
Jon -
Dave Deamer had mentioned he had a Jule frame on his BN1 - it occurs that maybe the mis-alignment of the MC mounting bracket is due to a difference from the stock frame.
At some point it would be helpful if you could verify this one way or another.
Re: the flywheel - suggest speaking with British Car Specialists and see if they could sell you a used BJ8 flywheel and possibly lighten it.
glemon
I had my 100 flywheel trimmed a bit, as I recall the motor was first used in trucks or vans, so starting under load was more important than acceleration.
The flywheel has a big ring protruding out the back, this can all come off, I had that and a little more taken off my car. I think it went from 30 some pounds to a little over 20. No drivability issues at all, big torque of the Healey made for smooth starts even with the higher gear of the BN1 3 speed. I can't really say what it did for performance since I rebuilt the very tired motor to higher spec at the same time.
roscoe
roscoe
Martin Jule probably found something that was tweaked on every big Healey ever built and said, " I can make that right". I will give a full report when the job is done.
Thanks for the flywheel info. I'll probably decide when I see what it weighs and consult with the engine shop I'm going to have do it. I'll have to change my signature to "Do it mostly yourself, you'll be glad you hired an expert when you need one".
DerekJ
Regarding flywheels. The standard 6 cylinder is about 28 lbs, the DWR steel replacement I installed weighs 13 lbs and is still perfectly driveable on the road and idles without any problem. You can easily take off 10 lbs, removing weight closest to the perimeter will have the biggest effect.
steveg
Mike Salter, with considerable 4-cyl racing experience, may have an opinion about how light a flywheel to go on the un-counterbalanced and breakable 100 crank. it's not the same thing as dealing with the 6-cyl cars.
HealeyPassion
Re: Caving in
John, I did the same thing ... pic enclosed.... Jags had a nice addition for that.
Jim_Gruber Correct Transmission Oil for Datsun 210 5-speed Spridgets 1
PAUL161 Jag 5 speed? Jaguar 5
T Datsun 5 speed potentially available from wrecker: Spridgets 0
Bayless What oil for Datsun 5 speed? Spridgets 7
L General MG Five speed MG 6
K Putting a Getrag 5 speed OD transmission in a Jaguar Mkll ? Jaguar 4
D Wanted WTB - clutch fork and shifter from Datsun 5 speed #60 Spridgets Classified 0
G 5-Speed Conversions Austin Healey 15
J TR2/3/3A TR3 Soft top speed limit? Triumph 9
Michael Oritt Pilot Bearing Adapter for Smitty's 5-Speed Kit Austin Healey 3
T Rut's 4 speed shifter modification - anyone have knowledge? Spridgets 3
Popeye Wanted WTB: two speed wiper motor TR4A / 75568 - Found Triumph Classifieds 2
shadowfever Datsun 5-speed info neede Spridgets 5
Michael Oritt Smitty's Five-Speed Manual Austin Healey 1
S TR2/3/3A Moss Motors Vitesse 5 Speed Conversion Kit Installation Issues Triumph 13
PAUL161 T-Series 5 Speed Road Test MG 25
PAUL161 T-Series 5 Speed Transmission MG 85
WHT Tremec T-5 Five-Speed Transmission Austin Healey 39
Michael Oritt Difficult-Shifting Toyota Five-Speed Austin Healey 17
crispy Idle Speed Variation Austin Healey 19
Cappy Toyota 5-Speed Austin Healey 3
Cappy Toyota 5 Speed transmission Austin Healey 4
T Wedge TR7 4 speed wheel cylinders on 5 speed (locating pin) Triumph 0
G TR4/4A "Engine seized after engaging overdrive at low speed. Triumph 26
T maybe a Datsun 210 5 speed available in Oakland? Spridgets 2
B 1966 TR4A two speed wiper motor Triumph Classifieds 1
I GT6 A type OD vs D type - engagement speed? Triumph 3
HealeyRick Toyota 5 Speed - Truck or Supra? Austin Healey 16
Michael Oritt Toyota 5-speed shifter bushing Austin Healey 7
roscoe 5 speed conversion question Austin Healey 9
Lin Toyota 5-speed bell housing drain hole Austin Healey 14
S For Sale 3000 BJ8 Laycock 4 speed with 22% OD trans & 2 6 cyln engines / long blocks / BUNDLE Austin Healey Classifieds 1
HealeyPassion Aftermarket heater/defroster with 3 speed fan Austin Healey 15
Editor_Reid “Healey: Cars for Speed & Glamour” Exhibition Austin Healey 5
S TR2/3/3A Speed O not working Triumph 27
M TR6 5 speed conversion Triumph 33
PAUL161 T-Series Who's still building 5 speed conversions. MG 4
Zitch For Sale TR4 - 4 Speed Triumph Classifieds 7
mctriumph For Sale 5 speed kits for supra conversion Triumph Classifieds 0
B "Healey 5-Speed"/Pete Delaney Contact Austin Healey 27
M 5-speed, 1968, 4.2, E-Type, OTS Jaguar 3
Bayless Question on 1 speed wiper motor Spridgets 2
Rut 5 speed install Spridgets 14
drooartz Leaking 5-speed drain plug Spridgets 26
Michael Oritt Toyota 5-speed Problem Austin Healey 28
F TR6 Squeal When Turning Sharply at Low Speed Triumph 6
S Wedge 4-speed gearbox problem Triumph 6
J For Sale 1976 Sptifire with 1.8L Miata engine/5-speed [running like a boss!] Triumph Classifieds 0
