AlfaHealey
Hopefully some day I will be more able to contribute and not just seek advice. Thanks to the sound advice received on this forum, I am attempting a clutch replacement on my '59 100-6. The original sideshift transmission had been replaced with a center shift unit. I removed the Gearbox Cover and found that it was the original with some modifications to accommodate the center gear shift lever. Since the cover is pretty beat up, can it be replaced with a new centershift cover or will there be problems fitting it at the firewall end or elsewhere? Also, is the rear engine oil seal difficult to replace?
Now for the cat problem: While I had my head buried in the driver's side wheel well, I realized that either an animal had died or a cat had decided to turn the nicely carpeted inside into it's own LBC litter box. In short, it smells of urine or some other gastly scent. I have used all types of cat-be-gone sprays and cleaners, but the smell persists. It has permeated the entire drivers side carpets and beyond. Any suggestions? Hate to replace carpets since they are in great condition. Thanks for help. Eric
