TR6 Casting plugs aka freeze plug size TR6
TR6oldtimer
My eyes are not as good as the once were, so does anyone know the size of the casting plug size on the exhaust side of the engine? I measured 1.5 inches. Also the size of the plug for the rear cam journal, which I have at 2"?
Also, a list of plugs and sizes would also be helpful.
Thanks
Brosky
Ray, I've got those numbers/sizes somewhere. Just let me find it.
TR6oldtimer
TR6oldtimer
Thanks Paul.
My original post referenced a TR6, when in actuality it is a TR250 engine, not that it matters. Anyway, I once again checked what I have, and the five plugs on the side and back, are actually 1.5", not the 1.375" as indicated in the reference. All the others are as specified.
Brosky
That's odd. I bought the 1.5" for mine, per the Dorman catalog and had to return them and get the 1.375" to fit. And I didn't fit them, the machine shop did. Maybe the earlier castings were bigger?
TR6oldtimer
TR6oldtimer
Strange indeed, 1.5 is what they were.
Brosky
Very strange indeed, but after your piston story, maybe not so strange after all.
Dorman 565-025 Cup Type Expansion Plugs
Dorman 565-025 Cup Type Expansion Plugs Features:
• Nominal Dia.: 1-3/8"
• Metric Dia.: 35.24mm
• Type: Brass
• Height: 0.310"
• Closed End Dia.: 1.382"
• Open End Dia.: 1.392"
• Brand: Dorman - AutoGrade - Boxed
Details and Features
* Oversize: No
Here's a picture of what I took to the shop after the exchange:
I TR6 Freeze [casting] engine plugs, 69 TR6 Triumph 8
H Is there any difference in using the 1275 Float Bowl that have a different casting? Spridgets 6
Michael Oritt Rear upright casting--source needed Racing 4
Michael Oritt Casting number on upright Austin Healey 3
Steve P. 6-port head casting numbers? Austin Healey 6
5 BN4 cylinder head casting change date? Austin Healey 5
M bn-7 [mk1] block casting number Austin Healey 2
M_Pied_Lourd Head Casting Numbers Triumph 2
vping MGB MGB Engine Block Casting Numbers MG 2
weewillie casting numbers British Motor Corp 5
2wrench Photo of casting defect Triumph 14
F cleanilng aluminum casting Triumph 15
T Triumph steering levers/arms with casting #s Triumph 0
aeronca65t 1275 crank casting #? Spridgets 26
mjamgb Block casting numbers MG 7
jcatnite Head casting number Spridgets 3
jcatnite Head casting number Triumph 0
B What does the 12G casting mark on the block mean? Spridgets 8
K TR2/3/3A Carbon buildup in an intake manifold and on spark plugs....... Triumph 0
trglory TR2/3/3A TR3a spark plugs Triumph 1
K TR2/3/3A Heavily carboned spark plugs in relation to a failed FO8 gasket? Triumph 12
bighealeysource Leaking Overdrive and Gearbox Drain Plugs Austin Healey 19
L T-Series Spark plugs again ? MG 2
B TR6 Gas on spark plugs Triumph 7
S TR2/3/3A Aluminum oil gallery plugs Triumph 9
kodpkd Spark Plugs Austin Healey 3
L TR4/4A spark plugs Triumph 9
A MGB Welsh plugs MG 9
HighAltitudeTR3 T-Series Why are there nuts in my core plugs?! MG 8
M For Sale NOS Champon NA-10 Spark Plugs Jaguar Classifieds 2
Gliderman8 TR6 Spark plugs for TR6 Triumph 7
B TR4/4A Spark plugs Triumph 1
B Resistor type vs non-resistor type spark plugs for 100-6 Austin Healey 17
S Spark Plugs Spridgets 2
AUSMHLY BJ8 NGK Spark Plugs Austin Healey 13
AUSMHLY When to replace spark plugs Austin Healey 1
K TR2/3/3A Anyone running NGK spark plugs? Triumph 26
longbridgehealey NGK plugs Austin Healey 23
S TR2/3/3A little rubber plugs Triumph 3
S TR2/3/3A Overdrive drain plugs leaks Triumph 3
A Oil Galley Plugs Spridgets 0
M TR2/3/3A Crankshaft Oil Galley Plugs Triumph 7
tahoe healey Spark Plugs Austin Healey 20
I Weeping Core Plugs Austin Healey 6
G spark plugs Austin Healey 10
R General Tech Aluminum oil gallery plugs Triumph 3
S TR4/4A 1/2" blanking plugs Triumph 2
I Tips for installing intake manifold plugs in a stock Bugeye? Spridgets 6
vickxxx T-Series 1952 MGTD spark plugs. MG 4
Tim Tucker TR4/4A Reading my TR4's plugs [L-87YC] Triumph 8
