Okay fellows, it's been a number of years since I took an active part in my B-GT's life, beyond the occasional grocery run. It's been longer since I was even remotely active here (my apologies, Basil).
Given Basil's unabashed enticement (watch give-away) I have decided to post this here and see where it goes.
Here's the scenario -
My 74.5 GT has been a "recreational use" auto since I acquired it and returned it to use. That describes the last 11 years. I have enjoyed the benefit of "employer provided" transportation during that time frame. Now there's a possibility that I might have to rely on the GT as a daily driver.
Eleven years or so ago, I spent more hours that I care to admit sanding and repairing, then painting the car. As I was not satisfied with my own paint work, I never invested the effort to protect the paint. Needless to say, it's dead, and I have a few spots that again need attention.
Given the possibility of it becoming my primary transportation again, I am preparing to disassemble/strip the car down for some in-patient care at one of the local paint and body shops. My plan is to deliver the car sans trim, lights, bumpers, mirrors, antenna, window trim, interior panels, etc., so that the body work and paint can be completed with as little overspray as possible. There's less likelihood that little bits and pieces will be messed up at the body shop if I remove and reinstall them myself.
The bumpers and marker lights were removed last night.
Now you're up to speed.
My questions / requests for input from you are these . . .
1. Carpet
Among other things, I plan to remove the carpet during the body shop prep work. It's currently the original carpet. The smell reminds me of the inside of my Grandfather's 1963 VW Beetle (during the late 60's), and if I close my eyes when I first get in the car, I can almost envision my Grandfather - but that's a different rabbit trail). The carpet is unfortunately past its prime, and has raveled, worn, and torn sufficiently so that replacement is warranted.
With respect to the carpet, what's your suggestion about "original" style replacement (smell being a plus), or a fitted kit of modern variety?
Mickey Richaud, you posted some nice photos in your GT Conversion post a few years back. I'd appreciate your input.
2. Sound deadening/proofing
Seems a given, since I'll have the interior disassembled anyway, that I should consider installing a layer of sound proofing. My ears ring constantly, and extended time in the car aggravates that a bit, not to mention that new cars have us all spoiled when it comes to sound levels.
I've read about various products, dynamat, n-butyl rubber self adhesive roofing products, cloth batting, etc. I'm open to suggestions here. Please share experiences with what you've tried, and the results, either good or bad.
3. Painting bumpers
Okay, damask red, rubber bumpered GT. As much as I'd like to repaint in a different color (saw a beautiful burgundy metallic RBB here - https://www.youtube.com/watch?v=iF-JgHtbugg) I'm leaning toward the same or a similar to original color. That's a discussion that's been repeated, no need to flog that horse again.
I have two sets of bumpers. Both sets are "unmolested," so to speak. There's the pair that is original to the car, and a "spare" set. I'm tempted to have the spare set painted to match whatever color I have the car painted. That way I can change the "look" by swapping bumpers.
Do you have any thoughts, one way or the other? (While you're at it, if you know of a "modern" lightly metallic maroon similar to Damask Red and want to make a suggestion, I'm still open to input.)
Logistics -
I spend most of the day in front of a computer, typing, researching, drafting, and occasionally, writing a post.
I must re-focus on work now, and will probably be in the garage working on the car tonight and tomorrow, and wrapped up with church on Sunday.
I'll do my best to get online and check for responses at least once this weekend, and as often as time permits in the coming week. So, if I'm a bit slow on the reply you know why, and have my apologies.
On a side note - Basil - if I remember correctly, some time ago you posted either here or on another popular MG site about brakes. If memory serves, you suggested certain parts - rotors, pads, etc. The GT is due for brakes, and I'd like you to refresh my memory about what you said, if you can. System is standard/oem. I do have a booster with master cylinder, pedal, and pedal box available from a later model B, but I remember hearing about a space conflict between that setup and the oem air cleaners for the twin SU's. If there's a way to do it, I'll install that also.
So much to do, potentially so little time.
1. Carpet
3. Painting bumpers
Logistics -
Hi Guest!
