PatGalvin
So, I'm installing carpet on Gwyneth (My British Mistress, aptly named by my better half), and have learned a couple things.
First, easiest way to locate and make holes in carpet for seat tracks is by running an awl through the captive nut beneath the floor boards and then chasing the awl with a hot soldering iron. If you try and drill the carpet, you will snag and your intended little hole will be very large before you can react.... So, burning the hole worked well. The hole is covered by seat track anyway.
For seats purchased from Too Tall Tim of Ohio, I needed to add a small spacer (quarter inch) to raise the seat track. Otherwise, the seat dragged on the floor and just could not be easily slid fore and aft. So, I grabbed some oak trim from Home Despot and cut to size. Worked well and doesn't look too bad.
Third, the seat tracks from TRF were a little problematic. The seat slide with the lever (to adjust seat fore and aft) required some tweaking. The slide lever fouled the seat base before the lever was actuated adequately to unlock the seat slide. So, I had to heat up the lever with my oxy/acetylene torch and bend the lever outwards to allow the required full travel of the lever, without fouling the base.
Use a little lube on the seat slides (I used white lithium spray grease).
With that, I'm pretty happy with the installation.
Hope this helps the next guy.
Pat
Pat
