My new B came with new carpets installed. Problem is "new" was installed 11 years ago. Carpets are absolutely perfect but the 1/4" orange foam padding has disintegrated from age. I removed all the carpets, scrubbed off all the residue from the padding. Washed with soap & water and a scrub brush on the driveway and hung on the cloase line to dry.
So now I have a new set of carpet again without padding and want to reinstall.
What should I use and how should I prep the floor or panels that they are going on.
The floors have some surface rust and the rubber sills are still decent. I just don't want to start gluing these down if I am going to have a major problem with it so I ask before I try and wing it.
Lastly since the sills are decent, are these sill rugs tossed or should they be installed. These carpets might be there a year or 10 not sure which direction the amount of re-doing this car is going to see.
