RJS
Hey All,
I started noticing a miss or stumble in the engine when pulling away from a stop sign. A quick inspection turned up a slightly carbonized ignition rotor. I was able to quickly clean it off with a scotch pad and all is well again.
However, just curious if this was a symptom of some other malady? I've never had this issue in 11 years. I should note the engine has been running cooler this year from what I strongly suspect is a thermostat stuck open - could that be the cause?
