aeronca65t
Kent Carnage!
I thought Kent engines were unburstable. Guess not.
This lump came out of Cal Trumbo's Formula Ford Kent engine during a practice session at the Jefferson 500.
There is actually part of the block attached to it.
This was #4 piston.
The flywheel was still attached to the remainder of the crank and you could spin it by hand.
This apparently happened while the engine was at a moderate RPM and not screaming. No oil pressure problem and no overheating. It just let go. Weird.
This was #4 piston.
