rnpennington
OK, I didn't follow the directions in the title and I touched them. Didn't drive the car for a while and the floats got stuck and fuel was pouring out the bottom of the carbs, ZS 175CD carbs. OK, easy fix I think, took the carbs off, opened the bottom to reset the float, changed the o-rings in the jet assembly. However, it took about three weeks for this all to happen.
Now, having taken them apart I know I have messed up the settings from before. How to I get it to a setting that will run the car and allow me to adjust it properly? At this point, it will not run, only start with starting fluid.
First question, what I have marked as Part 1. Is this screwed in all the way to the top or some other position?
Second, once part one is fixed properly, do I screw part 2 in all the qway and back off a certain number of turns or what?
Thanks for the help!
