I am trying to remove the carbs (SU HD6's) on my BT7 to replace the gaskets to the manifold. The front carb came out fine, but there is not enough clearance for the rear carb. The float chamber hits the frame before the carb comes clear of the studs. What is the trick to getting it out?
Chris
Chris
